Two questions about projecting a previous solution as initial condition for the next simulation:
1. Can I do it in Hypermesh? I only know how to do it in AcuCosolue
2. What it does is that it creates a nodal array of node id vs variable value, if I want to project a coarse mesh solution onto a fine mesh, the node ids will not match asI have more elements in the fine mesh, also the node numbering will be different. So this will not work?
Thanks.
