Hi !
I try to simulate a foam compression at a constant speed of 1 m/s. Before I have realised the same compression experimentally. In order to compare simulation and experimental.
I block every movement on bottom of foam and I imposed a constant velocity to impactor.
To go to approximatively 50% of strain there is no problem, simulation and experimental are the same.
But after Simulation disgress from experiemental.
I use brick elements of 1x0.5x0.5cm.
Anyone have an idea to solve this problem
