I'm a student in mechanical engineering, and I am just beginning with Altair HyperWork software.
I am currently working on a project to analyze the bending in endplate of race car front and rear wing.
These parts are made of 2 plys of CFRP and a Nomex honeycomb core.
I want to know if the end plate will fail under the aerodynamic loads.
From what I understand, for the carbon fiber ply, I can use the MAT8 Datacard and enter the ultimate tension/compression and shear strength.
For the Nomex, I think I have to use the MAT9OR and MATF Datacard. However, I am not sure which failure criteria is best for that.
I looked at the TSAI-WU 3D failure criteria, but it seems complicated to obtain the V10, V11 and V12 coefficient.
So, I wonder is there any approximation that I can use for V10, V11 and V12?
Otherwise, what criteria is usually used for orthotropic core like Nomex?
Best regards,
Frédéric Auger
