In the scenario I created, two plates are torqued with screws. However, the temperatures of these plates are different.
In other words, I want heat transfer to occur during torqueing.
But I am getting the following error. I tried the suggestions but couldn't find a solution. Could you please help? Also, what KCHTC value would you recommend for freeze and slide contacts?
Thank you.
Best Regards,
Ovunc
*** ERROR # 153 ***
Exactly zero pivoting encountered during Numerical Factorization;
the model may have rigid body mode.
Solver error no. = -503
spc set id = -5
index = 1
Possible reasons are:
1) insufficiently constrained model,
2) having rigid body mechanisms within the model,
3) extremely ill-conditioned rigid element sets,
4) extremely thin shells (as used for skinning) that have MID2/MID3,
5) gap elements with extremely high stiffness (KA, especially KT or MU).
6) extremely high Poisson's ratio in hyperelasticity material definition.
Check the model and rerun the problem.
(MECHCHECK may be used to find the rigid body modes. To do so,
change the input to be an eigenvalue analysis and add MECHCHECK.)
(WARNING: results obtained with MECHCHECK cannot be used because
the model is changed internally.) This error was detected in subroutine bcsmtxfct.
Solver FAILED
optistruct:: Solver run finished.
