I want to rotate a simple geometry around the axis passing through the center of gravity and calculate the required moment. I also compare the value I calculate analytically with the value I calculate numerically. For this, I used x and y elements and read the moments of reaction from the independent node of these elements. But in the scenarios below, I got different results.
In all scenarios, the coordinate of the independent node of the rigid element is (0,0,0). The rigid element’ s degree of freedom is limited only in ZZ (only number 6 has a tick).
- Scenario
All nodes on component were selected as independent nodes. In this case, no solution took place.
- Scenario
All but one node on the component are selected as independent nodes. RBE2 element used. In this case, the energy error was -99,9 %. So I didn’t expect it to give an accurate result. However, oscillation in the graph of reaction moment was quite low.
- Scenario
16 random nodes were selected as independent nodes. RBE2 element used. In this case, the energy error was -6,6% . I’ve observed quite a lot of oscillation. The mean value of graph was close to the analytical solution.
- Scenario
All but one node on the component are selected as independent nodes. RBODY element used. In this case, the energy error was 0,0%. Oscillation in the graph of reaction moment was quite low. But when I looked at the mean value of the results, I could not get a value close to the analytical results. I don’ t know if it was by chance, but it was about half the analytical value.
- Scenario
16 random nodes were selected as independent nodes. RBODY element used. In this case, the energy error was 0,0%. I’ve observed quite a lot of oscillation and the mean value of graph was close to Scenario 4.
When I move the piece linearly, I could get the numerical values and the analytical values the same for the reaction force. Also, when I use shell element, I can get the same result. Why is the problem I mentioned above? I want to get the solution as close to analytical value as possible, with minimal oscillation and energy error.
I added model and the table with the summary of the scenarios . I request your helps.
Thank you.
Best regards,
