Hello everyone, I'm attempting to complete a crash simulation of a bicycle helmet strapped to a rigid dummy head hitting a rigid wall with Radioss 2021. Shortly after initial contact, the foam liner apparently gets compressed too much so that a number of elements reach zero or negative volume as stated in the output file, after which the solver aborts the run. The foam liner is meshed with 3mm linear tetrahedra, whereas the shell is meshed with 3mm linear trias. For initial testing purposes, the foam is represented by a LAW36 tabulated plastic material law and the shell by an elastic LAW2 model. The property settings are mostly according to the recommendations from the Radioss introductory training documents. Please advise on meshing strategies such that their shape remains fit for calculation even under large compression. Would, for example, a size increase in the radial direction lead to convergence? I aim to retry the model with second order tetras, but haven't gotten a chance to do so yet. Unfortunately, I cannot share the model or images of it due to an NDA.
