I have been trying to select an appropriate material card for a material with the following properties:
E = 42.576 x 10^6 Pa
nu = 0.3
rho = 2650 kg/m^3
yield strength = 221 x 10^6 Pa
The material fails at an engineering stress of 418.9 x 10^6 Pa and an engineering strain of 0.00391.
I had originally tried using MAT LAW 2 (PLAS_JOHNS) with Iflag =1 for inputs of yield stress, UTS (engineering), and strain at UTS, but when I plot the function "stress = a + b*strain^n" (from RADIOSS reference guide 2020, p446) using the a, b, & n values calculated by RADIOSS, I don't get the expected stress-strain curve in the plastic region (first photo attached; a = yield, b = 276260135, n = 0.0779; orange line elastic region, blue line plastic region, solid black lines used for marking key points in material deformation behavior (yield and failure)).
I'm then just looking for some help answering the following:
(a) Why wouldn't the a, b, n values given create a plastic region curve that lines up with the end of the elastic region (expected curve is green sketch line in second attached photo)? Perhaps I've entered a value incorrectly?
(b) Since this material has distinct elastic and plastic regions, but fails before an actual reduction in stress on an engineering stress-strain curve (i.e UTS is the same as failure stress), is there a better material card to be using that would work with solid/brick elements and the known material parameters that I have? (I thought maybe MAT LAW 27, but this only work with shells)
Thanks in advance. Please let me know if I can provide any clarification to help with an answer to my questions/confusion.
