Hello everybody,
I use a modal requency response analysis to calculate the displacement of a component. I have already defined a set of nodes, which I use for calculating the displacement. So I receive the displacement in x,y and z direction at this predefined nodes. However, I am interested in the bending behavior, so I want to know the displacement of an element in normal direction.
Is there any possibilty to get to this solution in OptiStruct?
So the algorithm should calculate the normal direction of an element and than take the attached nodes for calculating a displacement in that normal direction.
I hope you have a solution for my struggle.
Kind regards,
Robert
