How to Apply Bearing Load in Newton in local cylindrical co-ordidate system. I.e I want apply load at an angle.
Unfortunately I could not able to select the local cordinates in selection window.
Note I have only the force (N).
Can someone help on this ?
or is there any alternative? eg. Like applying pressure on semiload angle of 90deg
If i decide for applying pressure,
Then P = F/A
Here for Area, do I need to take the complete circumfrential area of the bearing surface or only half
Kind regards,
SId
