Kindly explain how can I make an Interference analysis in SIMLAB or in Hypermesh optistruct
| | | Toleramces | Tol/class | Final dim | |
| | Dia(mm) | Max | Min | | Max | Min |
| Crank_Pin dia | 25 | 0 | -0.009 | h5 | 25 | 24.991 |
| Hole dia | 25 | -0.1 | -0.135 | | 24.9 | 24.865 |
| Interference | Min | 0.091 | | | | |
| | Max | 0.135 | | | | |
| | Avg | 0.113 | | | | |
If you have some example problem will be great.
or If you could refer me for some tutorial will also be helpful
Kind regards,
SId
