Linear Static Analysis with Thermal Boundary Conditions
mertcgunay
mertcgunay Altair Community Member
I am working on a project to simulate the cooling phase in an enamelling process. I simply generated a composite cantilever beam with two different materials to obtain the stresses and displacements during cooling process.
I will cool down the composite cantilever beam from an elevated temperature to room temperature. The problem is, I am new to thermal boundary conditions and I can't find the correct load collector combination to handle the problem.
To summarize the simulation;
1. Structure is at 350 degrees celcius and it will cool down to 20 degrees celcius.
2. Due to thermal expansion coefficent difference, the composite beam will deform.
Thanks in advance!
Mert Cevdet Gunay
Welcome!
  • Altair Forum User
    Altair Forum User
    edited August 2017
    Please refer to this tutorial 1085 Linear Steady-state Heat Convection Analysis
  • mertcgunay
    edited September 2017
    Prakash, thanks for your reply.
    I am actually trying to solve the problem not as a heat transfer but as a linear static analysis with temperature as the only variable. I want to define the cooling regimen as Temperature-Time graph and see the response of the bimaterial structure.
    Thanks
    Mert Cevdet Gunay
  • mertcgunay
    I want to make a correction.
    The problem I am defining above should be solved by Nonlinear Transient Analysis methods.
    Regards.
    Mert Cevdet Günay
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    Non-linear transient analysis is not yet supported for OptiStruct.
Welcome!
Welcome!
