I have to do the topology optimization of a single part in an assembly. The assembly has contact interfaces with friction so it will be a non linear static analysis with small displacements. For some reason, after some iterations, the simulation is not converging. I don't know where am i doing mistakes. I have attached nl.out file for your reference. Is it the definition of the design and non design space around contacts ? or is it the constraints, responses? I dont know.
Your suggestions will be greately appreciated.
Regards
Vikas M B
P.S I cannot upload the model file because of its confidentiality.
