I am doing a NL-Static analysis of an assembly (check the image). I have following questions:
1. A cabinet is fastened at the 4 locations (in the front) and it is rested on the 2 wedges below. The force induced by the cabinet is 1500N.
- The question is, should I consider RBE2 at only 4 locations where the cabinet is fastened? or should I consider the 2 wedges below along with the 4 holes to define the RBE2 (like in the Image) ?
2. While meshing the holes, should I create washersplit?
3. After creating washersplits, should I consider them for defining RBEs ? or would it be fine if I just considered the holes?
- both in 2D and 3D simulations.
4. While defining RBE2, Should i let the solver compute the independent node location? or can i define the location of the independent node?
5. I converted the above assembly into a 2D Shell elements (all the components have a uniform thickness of 2mm) for the ease of calculation.
- Here, I used midsurface tool to generate the 2D Shell elements. In the properties, I considered 2mm as the shell thickness and ran the simulation but the results were different (the stresses and displacenents) in comparision to the 3D results. What could be the reason?
