What have I done wrong with shuffle optimization, why the core ply change the position, actually it should not be stacked?
Paphatsorn
Paphatsorn Altair Community Member
edited May 2022 in Community Q&A
I am doing a shuffle optimization with monocoque structure with composite material, and the result of it did not correct. The core ply (Rohacell) should stay still. I do not know which steps did I miss?
As you can see the core ply which has orientation on 60 degree need to stay still as iteration 0 but the other plies should stack until the optimizer find and compute the optimal layout for this structure.
The result that I need to get will be like following picture.
I will attach the model file of my shuffle optimization, so you can check it out.
Thank you in advance. Please help me I am struggled with this for 3 days.
Welcome!
Best Answer
  • PaulAltair
    PaulAltair
    edited May 2022 Answer ✓
    I don't see your model attached, but did you define your CORE as such? for this to work as expected, you need to have a symmetric matrix too
  • PaulAltair
    PaulAltair
  • Paphatsorn
    edited March 2022
    Sorry for that, this is my model file.
  • PaulAltair
    PaulAltair
    edited March 2022
    You had specified only a single CREP repetition of a single ply as 'CORE'  this was satisfied by only having PLY 44, in attached I set CREP repetition instead to 9 which returns:
  • Paphatsorn
    edited March 2022
    Thank you so much, sir.
Welcome!
Welcome!
