Problem Statement: When exporting forces in Fluxmotor, one encounters the issue of obtaining tangential and radial forces for each stator tooth. However, the exported forces are not directly provided as tangential and radial components. Instead, they are dependent on the coordinate system centered at (0,0) in the Cartesian coordinate system.
Is there an internal solution available to transform these forces? If not, is there a method to output the precise position of the first stator tooth, referenced as the initial tooth in Fluxmotor, enabling subsequent coordinate transformation to derive the tangential and radial components?
Thank you in advance, your support is greatly appreciated.
Martin Wagner
