Kindly let me know, how I fix this Error.
The error seems to point to gaps/contacts in your model. I would recommend you check the contact definition, you can try different settings (n2s, s2s, etc), see if OptiStruct run past the error.
And try the latest version if you are not using it. The error might have gotten fixed.
