I am running a simulation with Acusolve and I try to investigate the effect of the Restart option at the final results. So I run the simulations in 3 different ways:
1) Using the job launcher of Hypermesh and letting Acusolve solve until it reaches convergence at the 31th time step.
2) I make an initial run through job launcher of Hypermesh, I stop the solver at the 20th time step and then I use AcuConsole's Restart tab to continue solving, initializing from the first run. The convergence is achieved at the 30th time step.
3) I utilize AcuConsole's Project tool in order to project the results of the initial (stopped) solution of the 20th step and then continue solving until the convergence is achieved at the 30th step.
The resultant force as shown at AcuProbe is the same for cases 2 and 3 (175N) while for the first case it stops at (207) N. This difference seems strange to me since the models for all the simulations have the same mesh and solver settings. I would expect that the calculated forces by AcuProbe would be the same for all of the 3 cases. Is something that I am missing? Any ideas why does it happen?
Thank you in advance.
Ntinos
