Hello.
I sub posted this in another thread however thought i might get more traction in its own thread.
Does HyperLife support LS-Dyna solution files?
It is noted in some of the HL help documentation that only OptiStruct, Nastran, Abaqus & Ansys are supported however when opening the initial model or importing results files via "Loadcase" the LS-Dyna option is available (as per attached image).
Upon importing LS-Dyna files however it appears no stress data is available as it doesn't show up on model when plotting stress fringe plots.
If LS-Dyna isn't supported why is the option avaialbe in the drop down list?
Can LS-Dyna be converted into H3D via HVTrans and then be usable?
Any help would be greatly appreciated.
Thanks.
