The optistruct solver is not be able to boot up from HyperStudy with student licenses directly.
Is it collect?
No, it should work with OptiStruct from HyperStudy using an Academic license.Are there any license logs or error messages?
Thank you for reply.
I would like to perform the parametric study using the parameterized file with ****.tpl.
Beacaouse I neeed to change the material ID for parametoric study.
If I select the model type for HyperMesh with ****,hm, the Test Models step is performed sucsessfuly.
On the other hand, when I select the model type for parameterized file, Test Model step is failed due to the license errors. (Error code #6 amd #9).
If you have some resolution idea for this problem, let me know it.
