I want to modell a bending process of a tube with a mandrel, which is made of a deformable steelrope on which several spherical segments (rigid bodies) are placed. I modeled the steelrope as a beam element, while the segements are made of shell elements. Since the beam element is a line-element I am not sure, which contact type is correct here.
I tried Type 19 with the Steelrope as Slave components and the Segments as Master component, but I get error 119: Lagrangian surface is empty. I think the problem is, that the program expects a surface and no beam elements. When I try to enter elements / faces instead of components as Slave it only allows shell elements.
So which Type of contact is correct to model such an interaction. The steelrope made of beam elements is defined as a part. Is the orientation of the beam elements relevant for the contact definition?
Thank you very much in advance
M.M.
