I have a mat footing with three piers. Two piers are subjected to compression and 1 is subjected to uplift. Due to the uplift load, Sfoundation is indicating an error. I understand what is going on here. but is there a work around to make S Foundation solve this model?
See attached pictures.
Hello Tom,
Thanks for getting in touch. This behaviour could be related to a number of different things. One of the first steps I usually take in this situation is to try and run the analysis as a Linear Static Analysis, rather than a Nonlinear Static Analysis, which is the default.
This serves two purposes:
I would suggest investigating these two items, and if that doesn't solve your problem, please feel free to open up a support ticket (see link below) so you can share your model with us, and we'd be happy to investigate further.
https://community.altair.com/community?id=csm_get_help&sys_id=de45c412c312310015519f2974d3ae1b
Regards,Matthew Sauer
Altair Support
