If IGBT in the attached psimsch file is simulated with a thermal model, the current appears to be on/off at level 0.
However, the voltage waveform cannot be switched at the 0 level and seems to be switched at the level of 0.7~8V. Ideal switches do not have this phenomenon, but the thermal model used in this circuit diagram file and other thermal models show similar voltage waveform characteristics.
Even if you don't input anything in the temperature pin, it works the same way, why?
Does the behavioral characteristics according to the purpose of using the Thermal model cause this situation?
