Hi all,
I have a model which presents me with the following....
"MUMPS failed in factorization because the run-time memory
requirement was larger than the estimated amount. Solver will
retry with a larger memory relaxation coefficient"
Am trying to understand if this is an issue or not (is the model being slowed, but a simple command/parameter will improve matters). My run command is "-core IN -checkel NO -out -np 8 -ddm"
The PC is an I9-9980HK with 8 cores (hyperthreading off) + 128GB ram.
