Hello Experts,
I am simulating fluidflow through 2 outlet one inlet manifold.
My inlet BC is 8.88 Kg/s with Bc type Inflow and other two as outflow.
After running simulation, I plotted graph of mass flux at inlet using acu probe, surface output.
Surprisingly, It was showing -8.88 Kg/s throughout the time.
But the outlet mass flow rate was 4.44 kg/s. Which is expected.
My Q,
Why is the sign convection is negative at inlet. From my understanding It should be Positive , ad I have given it as inflow with 8.88 Kg/s.
Kindly, give me your views.
Thank you in advance.
