Any tutorial available to explain step by step process to overlay test videos with simulation result. also can we adjust frame rate to match time incremental between test video and simulation.
Naresh Kini
Hello Naresh!
Yes, absolutely. Please follow this tutorial: HWD-0020: Animation Synchronization
The files can be found in the installation folder: C:\Program Files\Altair\2023\hwdesktop\demos\mv_hv_hg\animation\animation_sync
Kind regards,Paulo Libório.
Hello Naresh! Yes, absolutely. Please follow this tutorial: HWD-0020: Animation Synchronization The files can be found in the installation folder: C:\Program Files\Altair\2023\hwdesktop\demos\mv_hv_hg\animation\animation_sync Kind regards,Paulo Libório.
Hello Paulo.
I could able to follow and do a match. But how can I match exactly milisec by milisec. Do we need to do trial and error. And I can do improve it incrementally, as initial setting resets to default.
Any other better way to set it right. I used Animator and Metapost before and they are more easily tunable.
Hello Paulo. I could able to follow and do a match. But how can I match exactly milisec by milisec. Do we need to do trial and error. And I can do improve it incrementally, as initial setting resets to default. Any other better way to set it right. I used Animator and Metapost before and they are more easily tunable. Regards, Naresh Kini
This is quite an old example, for learning purposes only.
To get a "millisec by millisec" match, you'd need a video with higher frames per second and a smaller output interval request. Preferably, video FPS should have the same frequency as save interval.
Best regards,Paulo Libório.
