How to Overlay test video with simulation result in Hyperview?
Hello Naresh!
Yes, absolutely. Please follow this tutorial: HWD-0020: Animation Synchronization
The files can be found in the installation folder: C:\Program Files\Altair\2023\hwdesktop\demos\mv_hv_hg\animation\animation_sync
Kind regards,
Paulo Libório.
Hello Paulo.
I could able to follow and do a match. But how can I match exactly milisec by milisec. Do we need to do trial and error. And I can do improve it incrementally, as initial setting resets to default.
Any other better way to set it right. I used Animator and Metapost before and they are more easily tunable.
Regards,
Naresh Kini
Hello Paulo.
Regards,
Naresh Kini
This is quite an old example, for learning purposes only.
To get a "millisec by millisec" match, you'd need a video with higher frames per second and a smaller output interval request. Preferably, video FPS should have the same frequency as save interval.
Best regards,
Paulo Libório.
Hello Naresh!
Kind regards,
Paulo Libório.
