Altair RISE
Nominate Yourself Now!
How to Overlay test video with simulation result in Hyperview?
User: "Naresh"
Altair Community Member
Updated by Naresh
Hello,
Any tutorial available to explain step by step process to overlay test videos with simulation result. also can we adjust frame rate to match time incremental between test video and simulation.
Regards,
Naresh Kini
1 - 3 of 31
    User: "Paulo  Libório"
    New Altair Community Member
    Updated by Paulo Libório
    Hello Naresh!
    Yes, absolutely. Please follow this tutorial: HWD-0020: Animation Synchronization
    The files can be found in the installation folder: C:\Program Files\Altair\2023\hwdesktop\demos\mv_hv_hg\animation\animation_sync
    Kind regards,
    Paulo Libório.
    User: "Naresh"
    OP
    Updated by Naresh
    Hello Naresh!
    Kind regards,
    Paulo Libório.
    Hello Paulo.
    I could able to follow and do a match. But how can I match exactly milisec by milisec. Do we need to do trial and error. And I can do improve it incrementally, as initial setting resets to default.
    Any other better way to set it right. I used Animator and Metapost before and they are more easily tunable.
    Regards,
    Naresh Kini
    Hello Paulo.
    Regards,
    Naresh Kini
    This is quite an old example, for learning purposes only.
    To get a "millisec by millisec" match, you'd need a video with higher frames per second and a smaller output interval request. Preferably, video FPS should have the same frequency as save interval.
    Best regards,
    Paulo Libório.
