Why does the stress results for a 1d meshed component and 2d meshing for the same component given answers which are totally very different. For example in my case for 1d meshed the stress value was 40Mpa and for 2d meshed its 300Mpa
unfortunately from the info you have supplied it's not possible to say anything.
Hi Sir,
I have attached the results below also the file please check what else more info do you need pls let me know. See here I am not able to understand why there is a big difference in stress vlues also in 1d meshing Axial stress and displacement values are also very close why is that so?
Please let me know the answers
