Hi all,
 I would like to know about the method for calculating torque of geometry in EDEM.
 1. Regarding the radius used in torque calculations, I think it is calculated using the forces and distances acting on each facet of the geometry. For this distance, does EDEM refer to the distance from the rotation axis or the distance from the center of mass of the geometry?
 2. In the case of simultaneous rotation and translation, is the coordinate movement of the center of mass or rotation axis due to translation considered when calculating torque? At this time, It specify the geometry as a selection during the result export and assume that the Specify Axis is not used.
 3. If I calculate the motion of the geometry using a mechanism analysis software (Adams) without setting Motion in EDEM and update the geometry position in EDEM, will the coordinate movement of the center of mass or rotation axis due to the geometry movement be considered when calculating torque?
 Best regards,
 Oshiro
