Hi all,
I'm practicing using Simlab. However, I could not find cards similar to " Gobal OUT ", " LOADADD",..like Optistruct is on Simlab. So does Simlab have the cards i mentioned?
Thank you.
SimLab works a little bit differently than HyperMesh in this sense.
LOADADD is created automatically when 2 or more loads are combined into the same analysis in SL.
GlobalOutput Request is there when you select the outputs in SimLab, but it just does not show you this name.
There you will have elemental resullts, nodal results, etc..
SimLab uses an engineering language, that makes sense for newer users that don't know exactly the card names for the solver.
SimLab works a little bit differently than HyperMesh in this sense. LOADADD is created automatically when 2 or more loads are combined into the same analysis in SL. GlobalOutput Request is there when you select the outputs in SimLab, but it just does not show you this name. There you will have elemental resullts, nodal results, etc.. SimLab uses an engineering language, that makes sense for newer users that don't know exactly the card names for the solver.
thank you very much
