 I am setting up a simulation of a device in space to analyze a thermal management system. This is made up of insulation and multi-layer radiative cooling components.
 I set up the same model in Ansys Mechanical before, it uses a view factor radiation model and calculates radiosity from surface-to-surface and surface-to-ambient (3 Kelvin, vacuum).
 Originally I was processing this model in HWCFD, however, the implementation of P1 or DO models is too time-consuming while we are iterating out the design. I would like to replicate the model I made in ANSYS before but running into some issues. The OptiStruct reference and command manuals seem to be less detailed than the AcuSolve one.
 I am using non-linear steady-state heat transfer. There is a wall temperature BC of 2000K at the centre of the device and a wall heat flux of approx. 700kW/m2. I have split each surface layer such that each body has an internal (_I) and an external (_O) radiation surface. I have assumed the absorptivity and the emissivity are the same.
 However, I notice it says "view factor". I can't be expected to calculate the view factor myself, can I? It's a simple calculation for a computer to do in minutes. And it's a long tedious one for me. So I am assuming it gets calculated if I leave it as zero, is that correct?
 Ansys Mechanical asks to indicate if it is surface-to-surface or surface-to-ambient, How do I get something similar in SimLab?
 Would appreciate some insight, thanks!
