I have two tubes bonded by a glue. One tube is clamped while other tube is loaded via static load.
In hyperview upon applying the displacement the tube that is clamped is blue (no displacement) and no sign of the other one. However upon clicking the linear static mode the tube with the force flickers. ?
.out file features following:
*** WARNING 1932: PSOLID 5 is not referenced.
Referrence? What is that? I definetly got it 'assigned'
*** WARNING # 312
In static load case 10
the compliance is negative or large 3.357072E+10
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
Compliance? What is that?
