in topology optimization click on ossmooth shows invalid input model
Make sure you have selected the right .fem file.
The names of .fem file and .sh should be the same.
If the model is already loaded, you can toggle to 'Use current'
Note: Export the deck to the same working directory before you 'use current' option.
I am following OS-3020 tutorial and at the OSSmooth button click I get 'Invalid Element Count in .sh file'. I tried using 'use current' like you mentioned but still no luck.
Thanks
Hi @Mou
In OSSmooth, can you uncheck ISOSURFACE and try again?
Hi Prakash,
can you briefly explain this error. I got the same problem and was resolved when I unclick the Isosurface.
Thanks and Regards,
Punith Guptha
Hi Punith,
What is the optimization about?
What do you mean by Unclicking ISOsurface?
I am running an freeshape optimization and would like to extract the geometry of new design. I got an error when I tried to do reanalysis saying that invalid element count in .sh file.
Uncheck the ISo surface and it should work. Shape optimization works on node movements and not on material density changes.
I extracted the new mesh and now I would like to export the geometry to .Step or .iges format. It is ging me the error saying that invalid element count in.sh file. I have attached the image for the options I used.
Punith,
Uncheck the ISO surface block and change the option from NONE to SHAPE make sure your OSSmooth panel looks like as shown in image
thank you so much. It worked.
Punith
one more question. I see that when I export the model in .iges format my designers are not able to import it in CATIA V5. They are able to read only in .step file format.Any suggestions?.
Not sure. If there is any error while Importing in CATIA V5 please let us know also check with CATIA support about the same.
hello, i have the same error and try it like you say. But the result is and not smoothed model. How can i fix it?
You can follow up in below post.
