1 - 14 of
141
You can follow up in below post.
https://community.altair.com/community?id=community_question&sys_id=8ca6847a1b2bd0908017dc61ec4bcb86
in topology optimization click on ossmooth shows invalid input model
Hi,
I am following OS-3020 tutorial and at the OSSmooth button click I get 'Invalid Element Count in .sh file'. I tried using 'use current' like you mentioned but still no luck.
Thanks
Hi Punith,
What is the optimization about?
What do you mean by Unclicking ISOsurface?
Hi Punith,
Uncheck the ISo surface and it should work. Shape optimization works on node movements and not on material density changes.
I extracted the new mesh and now I would like to export the geometry to .Step or .iges format. It is ging me the error saying that invalid element count in.sh file. I have attached the image for the options I used.
Thanks and Regards,
Punith Guptha
Punith,
Uncheck the ISO surface block and change the option from NONE to SHAPE make sure your OSSmooth panel looks like as shown in image
Punith,
Not sure. If there is any error while Importing in CATIA V5 please let us know also check with CATIA support about the same.
hello, i have the same error and try it like you say. But the result is and not smoothed model. How can i fix it?
Hi,
Make sure you have selected the right .fem file.
The names of .fem file and .sh should be the same.
If the model is already loaded, you can toggle to 'Use current'
Note: Export the deck to the same working directory before you 'use current' option.
