Altair RISE
Nominate Yourself Now!
ossmooth
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
in topology optimization click on ossmooth shows invalid input model
1 - 14 of 141
    Altair Employee
    OP
    Hi,
    Make sure you have selected the right .fem file.
    The names of .fem file and .sh should be the same.
    If the model is already loaded, you can toggle to 'Use current'
    Note: Export the deck to the same working directory before you 'use current' option.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-35283700-1421036352_thumb.jp
    Altair Employee
    OP
    Hi,
    I am following OS-3020 tutorial and at the OSSmooth button click I get 'Invalid Element Count in .sh file'. I tried using 'use current' like you mentioned but still no luck.
    Thanks
    Altair Employee
    OP
    Hi @Mou
    In OSSmooth, can you uncheck ISOSURFACE and try again?
    User: "Punith"
    Altair Community Member
    Updated by Punith
    Hi Prakash,
    can you briefly explain this error. I got the same problem and was resolved when I unclick the Isosurface.
    Thanks and Regards,
    Punith Guptha
    Altair Employee
    OP
    Hi Punith,
    What is the optimization about?
    What do you mean by Unclicking ISOsurface?
    User: "Punith"
    Updated by Punith
    Hi,
    I am running an freeshape optimization and would like to extract the geometry of new design. I got an error when I tried to do reanalysis saying that invalid element count in .sh file.
    Thanks and Regards,
    Punith Guptha
    Altair Employee
    OP
    Hi Punith,
    Uncheck the ISo surface and it should work. Shape optimization works on node movements and not on material density changes.
    User: "Punith"
    Updated by Punith
    I extracted the new mesh and now I would like to export the geometry to .Step or .iges format. It is ging me the error saying that invalid element count in.sh file. I have attached the image for the options I used.
    Thanks and Regards,
    Punith Guptha
    Altair Employee
    OP
    Punith,
    Uncheck the ISO surface block and change the option from NONE to SHAPE  make sure your OSSmooth panel looks like as shown in image
    User: "Punith"
    Updated by Punith
    thank you so much. It worked.
    Regards,
    Punith
    User: "Punith"
    Updated by Punith
    one more question. I see that when I export the model in .iges format my designers are not able to import it in CATIA V5. They are able to read only in .step file format.Any suggestions?.
    Altair Employee
    OP
    Punith,
    Not sure. If there is any error while Importing in CATIA V5 please let us know also check with CATIA support about the same.
    Altair Employee
    OP
    hello, i have the same error and try it like you say. But the result is and not smoothed model. How can i fix it?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
