I came across in the documentation that the life is calculated using the formula.
Sr = SRI1(Nf)b
But, even after maintaining the co-efficients, TRTMENT, FINISH and [KF] as 1, the results are off (when compared with the manual calculation using the above mentioned formula) by a random factor (approximately 0.5), for each unique component I take for fatigue analysis (Refer image attached). Why is it so?
What is the calculation happening at the back end of the software?
Why is the factor 0.5 coming into play?
