hi,
I was going through OS-2095: Frequency Response Optimization of a Rectangular Plate tutorial problem, I was not getting how the Iteration 0 is initiating, I mean software has to assign parameters to problem, I would like to know what the parameters are assigning by software for Iteration 0 ?
I was asking about Iteration 0 , because I tried assigning parameters for density & thickness values like mentioned below
I opened the ” _des.h3d ” file in hyperview, I checked the iteration 0 results for element thicknesses & element densities , i got the uniform values of 0 .915 & 0.9 respectively from contour plots. I given parameters i.e., thickness of 0.915mm & density = (0.9 * original density) to the problem . submitted for solution. I was getting results kind of similar to the iteration 0 results from optimization problem, but not matching. hence I would like to know about iteration parameters more clearly & how the problem is being setup. are my understandings correct while assigning parameters?
I would also like to know, how to calculate standardized density value , that comes in element density contour plot ? Is it the % of density value ( original density ) that was assigned to the design elements?
I want to understand clearly the .out file of optimization solution, if any document related to this , please let me know / forward to my e-mail ID ?
out file of the problem is attached please find it
Your feedback is highly appreciated,
Thank you!!
