Dear everyone,
I have some problems about setting up contacts for two bodies with zero Gap at initial time. Type 7 was used, and two brick solid components were set for slave and master. An error message was received as follows:
INTERFACE NUMBER. . . . . . . . . . . . . . 2
INTERFACE TYPE. . . . . . . . . . . . . . . 7
GAP MIN = 0.3000000000000
POSSIBLE IMPACT NUMBER: 77 (<= 1 *NSN)
** INITIAL PENETRATION = 0.3000000E+00 IMPOSSIBLE TO CALCULATE NEW COORDINATES OF SLAVE NODE 380483
ERROR ID : 612
** ERROR IN INITIAL PENETRATION IN INTERFACE
DESCRIPTION :
-- INTERFACE ID : 2
-- INTERFACE TITLE : DiPao_WaLengZhi
INACTI = 0
SLAVE NODE 380483 IS ON THE MASTER SURFACE
** INITIAL PENETRATION = 0.3000000E+00 IMPOSSIBLE TO CALCULATE NEW COORDINATES OF SLAVE NODE 377618
How to deal with this problem? Could anyone give some advice? Thank you!
