Problem with acceleration value in hyperview
I try to read the angular acceleration using TH/Node because I can't do it with accelerometer TH/ACCEL (there is only the linear acceleration). So i try first to see the linear acceleration on the same node using both (Th/node and TH/accel) to see if i have the same result but i don't. I read that there is some filter to use but i didn't find it (i have v13 version).
Thank you for your help! (Sorry if it's not clear i don't speak english very well /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Hi Momo,
to access filters in Hyperview/Hypergraph:
File>Load>Preference File>Vehicle Safety Tools
Filter category will then become available in the menu bar.
0 -
Hey Ivan; thank you for your answer.
I tried the filters available in the menu (Ideal, SAE, SAE J211/1) but i can't have the same value i have in the accelerometer. (when i choose the filter Ideal/low pass/1.65 cut off, i get closer to the accelerometer result but still not the same).
I don't really know witch filter to use. If someone could explain
Thank you!0 -
Use the filter in the menu bar and choose from many types. Then shift+click the curve and define filtering parameters.
NHTSA Butterworth was used in the below example, where the only parameter is the cut-off frequency to tune the response.
These are similar queries:
https://community.altair.com/community?id=community_question&sys_id=dd86c83a1b2bd0908017dc61ec4bcbef0 -
Thank you for your answer!
But i jsut don't know which filter to use; because for linear acceleration for example, the difference between the result with the accelerometer and TH/node is huge for my case. And i can't find the appropiate filter to use. Thanks
0 -
You're welcome.
From Radioss help on /ACCEL:
1The accelerometer option computes a filtered acceleration in a skew system.2These filtered accelerations provided by an accelerometer are used in either the Sensor option or in post-processing acceleration Time History without aliasing problems.3A 4-pole Butterworth filter is used.4The recommended value for Fcut is 1650 Hz (1.65 ms-1) to obtain a class 1000 SAE filtering.5In addition to these filtered accelerations, the accelerometer also allows output to Time History, the integrals of X, Y and Z raw accelerations projected onto the skew. These quantities are not used by Sensor.6If the skew is moving, the integrals of X, Y and Z raw accelerations projected onto the skew are not the same as the velocities projected onto the skew, as described in Time Histories. But these integrals in derivating Time History post-processor allows to retrieve the accelerations projected to skew without aliasing problems (Integration / Derivation acting like another filter than the 4-pole Butterworth).Share the model if the issue persists.
