Error 703
Altair Forum User
Altair Forum User
Drom when I was having memory problems, I trimmed down my model by deleting a chunk of elements.  However, when I run the optimization I get the following error after 12 iterations.
 *** ERROR #  703 ***
   number of design variables =     339111
        number of constraints =          3
    error code from optimizer =        900
 The optimizer failed to find a solution of the optimization
 problem at the current iteration.
 This error occurs in module 'appdrv'.
Any ideas?
Welcome!
  • Rahul_P1
    Rahul_P1
    edited December 2014
    Please attach the out file
  • Altair Forum User
    Altair Forum User
    Hi davewalker348
    Check if there are any constraints are violated. The error is due to many of your constraints are violated and optimizer is unable to find a solution.
    Please check .out file for most violated constraints and try to relax the constraint(s) value.
  • Altair Forum User
    Altair Forum User
    Attached is a .txt of the outfile (the forum wouldn't let me attach a .out).  In the meantime, I'll see what I can figure out.
    Thanks
    -Dave
  • Altair Forum User
    Altair Forum User
    Hi davewalker348
    I suggest you to go through OptiStruct FAQs.
    If you look into the out file the stress constraint is violated.
    if you are looking to increase the stiffness of the component, try minimizing  compliance as objective with a limit on  volume fraction.
  • Altair Forum User
    Altair Forum User
    So my orignal design had exactly that - minimize compliance with a volfrac set ~25%.  The problem I was running into was having gaps between members unless I set my density ratio relatively high, causing a higher than desired volume.  Since my real-life design (aircraft wing) does not need to be stiff, I'm trying to run the analysis with a max stress less than the baseline design.  I'll try it again on this design and see what happens.
Welcome!
Welcome!
