Dear community,
I have a problem with the composite size optimization if I set a value for TMANUF for the plies.
After the free-sizing, I use the sized model to perform a sizing optimization setting a specific manufacturable thickness for the plies involved (TMANUF).
The solver is able to run the iteration zero, but it stops giving me the following error when iteration 1 starts.
*** ERROR # 789 *** Invalid design properties w.r.t. the design variables were found. number of invalid property items = 6
This happens only if I set a value for TMANUF and also if I delete all the settings for maximum and minimum laminate thickness.
Unfortunately, I cannot share the model I am working on.
Any suggestion on the matter?
Thanks in advance,
Alessandro
