Optistruct Applying Strain
Hello, I'm in a introduction to finite element class and i'm trying to figure out how to apply a strain to my mesh in optistruct. I'm trying to apply strain to the nodes on the right side of my plate and I can't seem to figure out how to do this. Any help would be appreciated.
Hi Warren,
Please check the link:
http://www.altairuniversity.com/wp-content/uploads/2015/10/SPCD_TTF.pdf
http://www.altairuniversity.com/wp-content/uploads/2013/12/spcd2.pdf
Please follow the post:
0 -
Ok, I will look into this. Thank you
0 -
When I run my optistruct, i get the following error.
error #23
SID 1 used on Case Control data SPC is missing in bulk data
I'm led to believe this means that the SPC is assigned incorrectly somehow in the load collector, but how?
I created a SPC which I used to constrain nodes on the left side.
and I used an SPCD to apply a displacement to the right side.
I then used a load collector to call the SPC and SPCD.
0 -
Hi Warren,
You need to apply an SPC on same nodes where you have SPCD. Please update and try again.
0 -
Okay, I got it to work thank you. I have one more question though. I ran the analysis using optistruct and get results for overall displacements, but how can I get this information for a specific point on my mesh?
0 -
