Superelements assembly
Altair Forum User
Altair Forum User
Dear
I have an assembly that I have decided to divide into 5 subassembly (A,B,C,D,E)
Using Craig-Bampton method, each of this assembly has been condensed (h3ddmig but I have tried with .pch also) using only the visualization of plot elements (plotel3 and 4)
In the master model, the residual nodes (aset) of each assembly are connected each other using beam and rod with different dof (in order to simulate a mechanism) and a rigid with the master node grounded and I asked for a certain number of modes (normal modes).
NO ERROR in the output file but neither results (h3d) but a serie of OSxxxx_er.rs~
This is the what i have in the output:
 Lanczos solver warnings for eigenvalue subcase 1.
 - At some point in the process, an inconsistent inertial count was found.
   This implies that some of the calculated frequencies may be inaccurate,
   especially the duplicated frequencies. To avoid this, specify both bounds
   and keep the bound away from the currently calculated frequencies.
     *** warning *** the rayleigh quotient
     x'kx / x'mx for the      1-th eigenvector
     does not match the computed eigenvalue
          lambda (     1):    -9.86447590101136D-06
          x' k x         :     5.21843506993811D-05
          x' m x         :     1.00000000000000D+00
          discrepancy    :     6.20488266003924D-05
     x'kx / x'mx for the      2-th eigenvector
          lambda (     2):     4.00771124962063D-05
          x' k x         :     7.34242225598191D-05
          discrepancy    :     3.33471100636129D-05
     x'kx / x'mx for the      3-th eigenvector
          lambda (     3):     5.23449252423092D-05
          x' k x         :     1.36220146252925D-04
          discrepancy    :     8.38752210106160D-05
     eigenvalues and eigenvector residuals
               eigenvalues      norm of     estimated
             (radian/sec)**2    residual    accuracy
         -9.86447590101136D-06  2.4225D-06  2.4225D-06
          4.00771124962063D-05  1.2132D-06  1.2132D-06
          5.23449252423092D-05  3.9402D-07  3.9402D-07
 *** Warning for eigenvalue subcase        1
     Number of modes requested    =     3 (0 = all)
     Number of modes found        =     3
     warning status index         =    10
     maximum relative discrepancy =  0.83875E-04
 (Scratch disk space usage for starting iteration = 1 MB)
Any suggestion?
Regards
Welcome!
Welcome!
