Hi erveryone,
I'm trying to do a composite crash analysis. So I have to calibrate a square Composite Plate, consisting as 9 Elements, regarding the released Energy. I perform tensile and compression tests for every materialdirection. In tensile direction the model worked pretty fine, but in compression occure some unexpected troubles. Compared with the theory, the three Elements of the middlesection should be deleted and the total energy of 7 Elements should be released. With a coarse mesh size of 3 and 5mm this work well, but I cant't reproduce this behaviour with a finer mesh of 1mm.
Any ideas??
I use Law 25 in Crasurv formulation and tried out different constraints (Imposed velocity and displacement) and element formulations (QBAT, QEPH) but no effect.
Best regards
