Large rigid wall force problem
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
Hi all,
I'm doing a dropping simulation and I find the rigid wall force is strange. So I design a simple dropping model for checking. The rigid wall reaction force is also so strange similar to my problem.
In the early stage of dropping contact, the rigid wall reaction force is very large, I suspect this large force result. Is it real or due to the rigid wall formulation? Or how to solve this problem? At beginning, the distance between the Box model and the rigid wall is about 4mm, which means there is no initial penetration I think.
I have attached my model. The model is very small, it can be solved in minutes. Please help me find out the reason. Thank you.
Roy
Welcome!
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    I think this is fine. As the box impact with the rigid wall, with the mass there could be high reaction forces in the beginning.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    Hi George,
    What's your opinion? Do you think this initial large force is a numerical problem or a real contact force in physical?
    In my opinion, I think the contact force should increase from zero to maximum and then decrease to zero corresponding to the real dropping process. So I think the initial large force may be coming from rigidwall numerical problem. Is my understanding right or how to explain this strange phenomenon?
    Thank you
    Roy
  • gopal_rathore
    gopal_rathore Altair Community Member
    edited October 2017
    Is this force coming at t=0 itself or after some time? Also can you check with impact force analytical calculation using mass, velocity and time of impact.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi gopal_rathore,
    1. I think the initial large force occurred when the box and the rigid wall began contact. My model is very small, it only takes minutes to solve it, and I have uploaded my model in my first post. Could you run the model and help me debug the problem?
    2. What's your meaning impact force analytical calculation? Is there any simple model with theoretical solution?
    Thank you
    Roy
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    I think this is due to the initial contact happening.
    Can you please remove the added mass in the model, run the model and review the contact force.
  • gopal_rathore
    edited October 2017
    The issue is due to no proper distribution of mass. The added mass although distributed is taking cg at its visualisation node and thus making overall cg almost at the visualisation node and thus on impact with almost mass near the wall , the forces are coming higher.
    I have not run after modification, but this seems to be the problem as the expected cg of the system is not the same as in model.
  • Altair Forum User
    Altair Forum User
    Hi Roy,
    Hi George,
    Do you also think this large force due to numerical problem of rigidwall?
    I delete the added mass and change the material to steel, and the force is similar (there is also a large contact force in the beginning of contact). I have uploaded the new model. Please try run the model and debug the problem. The total cpu time to solve the model is less than one minute.
    Thank you
    Roy
  • Altair Forum User
    Altair Forum User
    Hi gopal_rathore,
    What's your opinion about this large force? Numerical problem or Real physical phenomenon? I create a new model with no added mass. The contact force result is similar.
    Please see attached file.
    Roy
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    I don't there is any issue with the numerical formulation of rigid wall. Instead of defining a RWALL you can try creating a surface and define an interface between the box and surface, run the simulatiton and review the resultant normal force.
    I also tried a simple ball drop  on a rigid wall and the plot looks similar to this.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    Hi George,
    I will try with a rigid surface you suggested. My main concern is that this large force is real or not. That is to say, if we can get the contact force from a drop test, does it also have this phenomenon? I'm very doubted about this.
    Roy
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    This is an initial spike happened which you can ignore. You can consider the curve from the next value.
    If this was a case like rebounding the curve would have been different.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi George,
    It seems that your curve doesn't have this initial large force. How this happen?
    Roy
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    The initial spike was trimmed out from the curve. Normally in these type of cases the initial spike is ignored.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    Hi Roy,
    Hi George,
    How to trim out the initial spike in HyperGraph? Could you show me some details? Thank you
    Roy
  • Altair Forum User
    Altair Forum User
    Hi Roy,
    Please go through the file attached which shows trimming curves in HyperGraph.
Welcome!
Welcome!
