I optimised a component through OptiStruct using Topology Optimization. You can perform a static structural analysis on the last iteration by inputting the following Solution Control Parameter directly on optistruct: PAR AM, REANAL, <density threashold>. However, I would like to check the performance of an intermediate iteration. Is there a way to do that?
Yago
