when using an ALE formulation i noticed that the mesh doesn't move at all while visualising results, the results however semm to be correct, is there a way to let the mesh move? how can i let it move the same way a lagragian mesh move? i need to use the ALE formulation because deformations are too important and a simple lagrangian formulation desn't work. also how do i create interaction between an ALE mesh and a rigid wall?
