Panopticon 2021.1 supports the ability to draw two types of path lines on map plots:
Analysts can filter the number of map points displayed on a map plot and the map will expand or contract automatically to accommodate the number of map points displayed based on the filter settings.
This video was produced with Panopticon 2021.1.
