The motor control design suite from PSIM will enable anyone to quickly get a motor spinning with a full switching power inverter implementing field-oriented control. The output of the design suite can be easily linked to a motion co-simulation or adapted to for whatever your design goals might be. Swap in thermal models to look at efficiency, add in non-ideal models to look at conducted EMI issues, or include your algorithms for control to verify performance. This tutorial video will give you a quick overview of how to get started.
https://www.youtube.com/watch?v=2Ouepi9PGI0
