🎉Community Raffle - Win $25
Join and Win
Understanding about a block
User: "Bhuvana Siva Teja"
Altair Community Member
Updated by Bhuvana Siva Teja
Hi,
I was exploring the Blocks available in Activate and came accross a block called "Volume".  I read its description given in their website and couldn't figureout what exactly it does. Can anyone help me understand about this in simple terms and its place of useage.
1 - 3 of 31
    User: "RoKet"
    Altair Employee
    Accepted Answer
    Updated by RoKet
    Hi Bhuvana Siva Teja,
    Volume represents the capacity of a hydraulic volume. Capacity is defined by volume / bulk modulus of fluid. The size of volume is defined by the volume between all connected components e. g. in a tube or mounting block.
    The component is necessary to calculate the pressure changes in the system. Note, that most of the components contain a dead volume which is added to the volume, resp. the dead volume can replace a volume component.
    OP
    Hi RoKet,
    So, if i use volume at any branch point, it will help me approximate the pressure different in detailed right? Bcoz after using it, i am able to see the graph of pressure oscillating to reach a steady state at pressure relief valve.
    User: "RoKet"
    Altair Employee
    Updated by RoKet
    Hi RoKet,
    Pressure oscillation depends also on other things (you need an additional inductivity, e. g. pipe), but in principle you are right.
